Lift and Milage.
If you installed larger tires and did not correct for that, thats probably the main reason your mileage went down. But as said, you can install gears, and you can buy a tuner to get some extra performance. Of course you can also do intake and exhaust, but the gears and tuner will be the more effective of them.
Any time you allow more air under the truck (lift it) you will end up with worse mileage. Leveling has a similar effect, because the approach angle is aerodynamically different than the wind tunnel work to make your truck effiecient. Add larger tires and it gets worse.
Depending on the tire size you used, gears may be necessary... if the change was small from stock, the gears won't show much change. Remember a wide tire is harder to roll than a narrow one.
Off-road lights are another killer - I get 2 mpg just by taking the 5 8" lights off the top.
That said, tuner will help either way. However, the very best thing you can do is keep your right foot off the floor. You've increased drag, so no matter what you did it will take more throttle to accelerate at the same rate...
lastlap, Can you in the new trucks just change rear gears? I know of course you can't turn on your 4 wheel drive but I thought even at that you had to re-gear front and rear at the same time in a 4wd.
And, I see this question all the time and can't understand everyone saying do ANYTHING but gears first. 35's on 3.73's are just putting an incredible strain on your driveline with out proper gearing. Its not just the MPG or performance. Those new tires, rims, and lift all of that weight combined is completely out of the design factor of the vehicle strengths. You are just helping your truck sooo much with getting gears and giving the drivetrain a break.
