Tell me if my pics look funny to you
So check it out, about a week ago, i pulled my bed off my truck so we could get better access to grinding off the hanger, so i could lower my truck.
Well when i was putting everything back together i noticed a hose disconnected near the differential. The guy i was working with says he thinks its just a bleeder hose, but i want to make sure something isnt wrong, it drives just fine now that i put shims in it, but just give me confidence things are okay under my truck.
This is the end of the hose, i tierapped it up so it wouldnt drag on the ground
This is where the hose goes into the back of the axle
Thanks again fellas.
-Patrick
-Patrick
I wondered the same thing when I did my gears im pretty sure someone correct me if im wrong but that is your vent hose for the rear axel. I asked the tech who did my gears the same thing but mine didnt have that plastic cover around the outside. I am guessing I could be right could be wrong. Good luck with it though...
Brandon
Brandon
So is it going to be alright if i leave it tie wrapped like that? or do i need to try and put it back into the bed crossmember?
-Patrick
-Patrick
