Liftin my Truck
Liftin my Truck
Gotta 97 2wd extended cab shortbed.....thought about goin with a levelin kit for the front 2.5''s with 3.5 spindles..........some blocks for the rear to level it out and then a 3'' body lift....so I guess about 9''s all together??? Was really excited about gettin into the process until I read on here that for the body lift you've got to un hook all kinds of crap underneath the hood and elsewhere(radiator, gas line to side of truck etc.).....Sounds like a NIGHTMARE!!!! Is it really that bad, or am I just worried about nothin??? Is it really that simple that I can just in stall the levelin kit, the spindles, and the body lift and blocks, or is it goin to require some jerry riggin on my part??? I am mechanically inclined but new in the liftin my truck business...any Ideas or words of advice on the process??? Thanks.
Originally Posted by wandell
The body lift isn't that hard. There are just a lot of small steps. Just buy a Performance Accessories kit. All of the little details are addressed and it comes with great instructions.
Performance accessories is definitely the kit you will want to buy! If you buy the PA kit nothing will be rigged it comes with everything you need to do it right like steering linkage extender, shift linkage extender, radiator drop kit, fuel fill tube extender and bumper brackets. The body lift is a 5 on the 0-10 difficulty meter. Basically if you are mechanically inclined, have a buddy help you, and if you have a 1/2 inch drive set with some breaker bars and extensions you'll be fine.
