Idler Arm has play in it??
Well I had my truck into ford for an oil change and when they looked it over, they said my idler arm has play in it. What does this mean??? How hard it is to fix??? They said I need an alignment after I fix it and they wanted $350 for it. Someone please help me....
Originally Posted by GreenLantern
Interesting! My ford dealer told me the front end didn't need a realignment when replaced.
It probably doesn't.
However, performing an alignment on a vehicle that doesn't need on is immensly profitable and it somewhat covers the butts of the dealer in the event your tires wear funny.
If the alignment was correct before the idler arm failed, it will still be correct after the arm is replaced.
Steve
i dont kno about other places, but sears ( i work there) in the auto shop will do an alignment for 60 bux. they set it up and everything and if everything is good and it doesnt need one u wont be charged for it. depending on how **** the manager is ( our manager is ok with it on slow days) they will let u get an alignment check ( even if it needs it u can say no and its free) we also have to give the paper work to show what the numbers for toe and all that were and what spec is. the ones that are out of spec should be highlighted ( depending on the tech) or they will have a * that the printer puts on it. that means that needs to be adjusted. just a thought if u wanted to see if it needs it or not.
idler arm. $150
ball joints. $500
front brake pads $100 ( and turn rotors )
alignment $ 70
TOTAL $888
Smile on dealerships face... $PRICELESS$
