body or suspension?
Originally Posted by farmgirl
i want to put a 3" lift on my truck...but...i dunno if i should do a body or suspension lift. plus, i don't have that much money right now, and a 3" suspension lift is like $1500!! but i want it to look good. so, if anybody has any suggestions, let me know.
Originally Posted by derekmc1
For a 2002 F150 4x4, would you need to modify brake lines or anything else when doing a 3 " body lift?
not if you get the PA bodylift. everything is included in the kit. the only thing extra is the gap gaurds and the shifter extention if you have a manual trans.
If you want to do it right do a suspension lift body lifts are tricky like they said and there not the best for any situation even when mounted correctly they give you more roll in your truck and if you ever offroad your truck ive heard storries of the bolts sheering off. so if i were you i would stay as far away from a body lift as i could.
bodylifts are not as bad as people think they are. granted yes a suspension lift is better, but bodylifts are still safe. i know someone with a 79 f250 w/ a 3" bodylift and suspension lift. he has done rolled the truck and the spacers, bolts, everything for the bodylift where fine. the cab was a little smashed tho. im not telling you to get a bodylift do what you want. all im saying is that bodylifts are not bad as people proclaim.
