4.6L and 35 inch tires
Originally Posted by notyet04
am i going to have a problem running 35's with an 04' 4.6 litre? will i need to regear? i have seen some posts say yes some say no...anyone have this setup that would care to answer? thanks
Originally Posted by 99fordman
My truck has the 5.4l with 35's and if I could afford it I would re-gear. With your 4.6l you are really going to want to re-gear you don't have to but I would strongly suggest it.
Originally Posted by bigplayer6907
i have a 2000 xcab with the 5.4, stock gears, and 6in fabtech but i still manage to break my 35s loose off the line if i try. i plan on changing gears soon though. with your 4.6 i would defenitly suggest regearing.
i'm just gonna get a 5.4L then. with way more power and better gears its worth it. how much of a difference am i gonna notice between the 3.73 vs the 3.55's? and the offroad package comes with rear limited slip ? so they have to say offroad package for it to have the limited slip?
i have a 98 4x4 f150, 4.6L, 6 inch fabtech lift, 35 inch tires, i didnt re gear my truck right away, i wasnt horribly disapointed in it either, ya it didnt haul ***, but i dont have a heavy gas pedal either, so it didnt bug me to much, i regeard to 4.56 awhile ago, and it does make a difference, bringing your truck pretty close to feeling like stock again. So i would suggest it, but if your ez on the gas, not regearing probally wont totally destroy your tranny, hopfeully lol
My truck still burns em off the line and accelerates pretty good. But I would like it to accelerate a little better. My truck has 3:73's stock, when I run 35's I am only running a 3:30. When I regear it I am going to change to 4:56's then with 35's I will have a 4:04 ratio which will be much better than 3:30.
I am running 35", with a Fabtech 6" lift. I regeared to 4.56 front and rear. It's a wise choice to regear.
Before:
https://www.f150online.com/galleries...445-109165.jpg
After:
https://www.f150online.com/galleries...445-114551.jpg
Before:
After:
i have 35's on mine with a 4.6. i originally had them on for about 6 months with 3.55 gears and it was pretty slow but it still worked. the gas mileage wasn't that bad, it just seemed worse because the bigger tires offset the speedo and odometer.
i then changed to 4.56's and couldn't be happier. the mileage isn't too bad as long as i keep it under 140km/h. at 140 and above i seem to get about 9mpg.
