cranking the TBARS
cranking the TBARS
How much would I really be able to crank my stock tbars if I just wanted to bring up the front end a little bit? I am going to put on the PA 3" body lift and go with 285's. Right now as it sits my truck is 1.5 inches lower in the front than in the back. I really don't want to max them out , but would a little bit hurt anything, like maybe just trying to get a 1/2 " out of them.
Another question,
I am going to go with the ultra type 164 rim 17x9 , with a back spacing of 4.5" , will there be any rubbing with those tires and wheels if I have that 3" body lift?
Another question,
I just cranked my t bars up an inch and put a 3 inch pa body lift on it( by the way word of advice have a friend help get your front two cab mounts they spin easily. I am putting 33 1150 17's on my truck tomorrow. will let you know if they rub. ride is still the same maybe a little rougher
Doc
Doc
You should be able to crank them enough to completely level the truck out. However, dont be shocked if you cant. Every set of t-bars is different, and every truck does not have the same amount of threads available to screw in. I have heard of some trucks with tbars fully cranked from the factory. Also, 5 turns on one tbar does not necessarily give the same amount of lift as 5 turns on another tbar.
285's will fit on a stock 4x4. With 17x9 rims, you might have some slight rubbing but nothing a little trimming the valence or cranking the tbars cant handle. If you crank the tbars and add a body lift, you will definitely be able to fit 285s with the 17x9's without issue.
Thanks for all the good info, sounds like I may need to run back down to lesschwab and get the rims and tires,
Wandell , I hav eread several posts about how far the tires wil stick out outside of your body. How far would these rims and tires stick out past my body if they would at all?
Another question,
Another question,
hey go to the "4 wheel parts" and get the front leveling spacer for $90. its easy to do. i put them on before i got my 3" body and i can run 315's.
