03 F150 Lowering Kit
Just wondering what my best option is to lower my vehicle and still retain my towing capacity which is 7700 on my model. Wont be pulling to its capacity, but possibly a 12-15 ft enclosed trailor with 2 Nice size riding lawn mowers in a year or so, so I still need good towing ability.
Most any kit will allow you to retain the stock towing capacity.
You usually get front coil springs, rear hangers, and rear shackles. If you have any problems you could install those 'helper' airsprings for when your towing.
If I was going to lower I think I would go for spindles (assuming its a 2wd) in the front and a shackle/hanger combo in the back, with the helper springs just incase I tow/haul anything heavy.
Has anyone used any of the ebay kits and how do they ride?
http://cgi.ebay.com/ebaymotors/FORD-...spagenameZWDVW
http://cgi.ebay.com/ebaymotors/EIBAC...spagenameZWDVW
I can't say I've used either of those kits, but my honest opinion is that the Eibach is the only one there even worth looking at.
BellTech and Ground Force are the only kits I've used or installed. Reputation and performance are what prompted me to use them initially, and 4 years later I'm still as happy as day one. I've never had a single issue with ride quality or broken parts. They're more expensive kits than most, but worth every penny and then some in the long run.
If you're looking for a 2/4 drop, spindles/springs/hangers/shackles is the only way to go.
Does this look like pretty reasonable pricing?
http://www.modacar.com/products/Ford...ch+Comple.html
Good kit (no go if you have 4wd though)
