4x2 vs 4x4
4x2 vs 4x4
I'm looking at getting either an 06 or an 07 f150 supercrew. What are the main differences between the 4x4 and 4x2's (skipping the obvious difference)? Suspension wise, do the 4x4's get a beefier suspension or anything? Also, what gives them the 3 inches or so difference in height, springs? or 3 inch body lift? Thanks
The suspension systems on the 04-07 4x4's and 4x2's are basically the same (IFS with coilovers). The 4x4's only sit about 2 inches taller than the 4x2's. In the rear, the 4x4's have a 2 inch lift block. Up front, I believe the coilovers on the 4x4's are slightly different. I would suggest deciding if you need 4 wheel drive. If you don't, you can save money on purchase price, gasonline, maintaince and insurance by going with a 4x2. And if you just like the looks of a 4x4, the 4x2's are easily lifted.
The reason I asked if the 4x4 got beefier components, was that I could justify it for pulling boats and stuff. But if there's no real advantage, then you're right about the economics of it. Thanks! I like the higher profile of the 4x4....would I be able to do something like a readylift leveler (or similar) 3 inches in front and 2 inch block in the back and accomplish the same thing? For several hundred bucks...
Originally Posted by Jims91
The 4x4 is nice when lauching boats in extreme conditions, like the boat ramp on the river thats always covered in mud. Or lauching the jets skis from the bank with no ramp. That 4 wheel low is a wonderful thing...............
My last truck was a 2wd, and i lost track of the number of times i got stuck using gravel launch ramps into the ocean and lakes. if what you're towing is any larger than a single jet ski, or if you are going to be using anything but the best boat launches, i would definately recommend a 4x4. either that or buy a winch!
Tanner
Thanks guys! I went to a dealer and looked, and am still up in the air on the issue of 2wd vs 4wd. It's not a big boat, but a bigger one may be in the near future. I currently use my 99 f150 V6. I'm definitely getting the biggest gas engine (5.4 i think) I haven't plunked down any money yet....you guys brought up some issues I hadn't thought of, and will definitely keep em in mind. Thanks!
Originally Posted by Silver05
I've always wondered why do the 4wd have to be taller in stance?
Also with a slightly higher rear end and overall ground clearance, going over obstuctions like logs (common out here where i am in BC) its much less of a problem.
Tanner
