New Shocks with 1 inch lift ?
I am thinking about going with the leveling kit on my 06 SC 4x4 but I will need to lift the rear app. 1 to 1 1/2 because of a 130 lb. tonneau and a good bit of weight for work {app 150 to 200 lbs.} in the rear.
Will a lift block of 1 to 1 1/2 require new shocks? I do some offroad stuff but never get my trucks really crossed up to extend the shocks much.
Hi,
I know its not what you asked but it seems if you got the 1 1/2in lift it would sit about level with the wt you are adding to the bed. I weigh about 280 and when I stand directly over the rear wheel, that side sags less than an inch. Good luck with what ever you decide.
swampstander
swampstander
Originally Posted by jjmIII
So, if you add a leveling kit (lift) in the front, you'll need to lift the back to match?? Couldn't you just leave it alone?? Or do you want a 1" or so of lift for cheap??
