camber bolt kit
camber bolt kit
i have one question for all guys with leveling kits on their trucks... i got a 2006 Screw and when i went to go talk to a guy about a leving kit he told me that i would also need a camber bolt kit to straiten out my tires after he put the leveling kit... if someone could tell me if i really need these bolts or not.. cause this is the first time i have ever tried doing anything to my truck and i dont really know much about this kind of stuff.. thanks alot...
If memory serves me right. A camber bolt kit was recommended to me when I did upper and lower control arms last year.
There entire perpuse is to make the alighnment easier for the guy doing it. I figure I'm paying the guy to do the adjustment. Why pay extra for parts I really don't need to make his job easier.
Just my 2 cents
Doug
Just my 2 cents
Doug
When I did my 4.5" suspension mod. on my 06 SuperCrew 4x4 the kit cam with new adjustable camber bolts. The FORD dealer that did my alignment after the suspension mod. stated that "When the truck is first built to spec. there is not need for the camber alignment bolts, so FORD uses NON-adjustable camber bolts during initial build" The FORD tech also said that as the name applies adj-CAMBER bolts are needed when the travel angel is extended to ensure tires are aligned vertically... After my suspension install It cost me 45.00 dollars to have this done, If I had not had the Adjustable camber bolts, the dealer wanted 250.00 dollars for the bolts plus the 45.00 dollars for labor. I'm glad my kit came with these... From what I've read most kits do come with these adj. bolts.
I am not sure if the leveling kits require camber adustment or just front end alignement. The FORD tech said "Camber adjustment is separate from the standard front end alignement."
Hope this helps. BoB
