Power Steering Whine..normal?
I have done a search and I found lots of info on similar problems. I have recently bought used a 97 4.6 with 122k and the PS pump whines when you turn the wheel (similar to when it is max pressure at either end of the directional lock). I guess the Ford PS pumps are noisy, but it is pretty darn loud. I also noticed the fluid is turbulent in the remote reservoir when the truck is idling. Is that normal? I might try to drain and refill with synthetic to see if that helps the noise.
