fabtech on top of as 2.5?
just found an awesome buy an dwant to do it, but how safe/ok is it on the parts. 2wd screw 04already bought an as2.5 but havent installed it. just found a 6 " lift for 1350 out the door. what are your guys opinions on stacking these two? not an offroader just like the mean looks
I'm still setting on the fence on this one. I'm thinking the 2.5" on top is too much, but that's just my opinion. I still may end up doing when the time comes and I get larger tires. Right now I don't need the extra 2.5". I'm not as concerned about the cv axle angles as much as the ball-joints.
Sounds like you are getting a great deal on the lift. If you want the extra 2.5" lift go for it. It's just ball-joints.
haha well im an x prerunner guy. i had a 96 f 150 with a cleveland 351 with 450 hp at the wheels, 9 inches wider in the front with 23 inches of travel on 14 " kings and 24 out back so i kinda dig the front end being higher. do u guys have any measurements from ground to bottom of mirror or bottom of bumper so i can get an idea?
definately do it, i have it done and love it!! You will need to get an AAL or blocks for about 2-3" in the rear to make it work. I have the fabtech lift, with the 2.5 AS up front, and added 3" aal in rear and a 4" block. sits perfect! I ended up with about 9" total lift after it and sits perfect you can check out my gallery but i still do not have the 4" block on there, its still the 2"
