Broken bars on front suspension
Those end links are easy to replace, and no alignment required. Just unbolt them and bolt in new ones. You can get aftermarket ones with polyurethane donuts for most vehicles for around $25.
The question is, why did they break? Are you doing a lot of rock crawling in your Screw? Is it raised or lowered? Usually the bushings wear out, split, or crush, but the bars themselves are pretty tough.
