do i need a aal with fabtech?
I am just days away from ordering a lift kit.. I keep going back and forth between fabtech 6 and the rancho 4. Then i saw a post on here, the guy said that most fabtech lifts come out with the *** end lower then the front, so you need to aal....... The guys ive talked to with the rancho say that they turn out perfect. so my question is, is this true bout fabtech? and if so how much more is it gunna cost me for the aal, if anyone knows.
This is a topic that is near and dear to my heart as I will be going with a 6" Fabtech kit in March. Since the Fabtech kits only come with 2" blocks for the rear (to make up for the nose down stance our trucks leave the factory with) I think either a bigger block or an AAL is a must. I am keeping my 2.5" AS leveling kit on mine on top of my 6" lift to ensure I can fit 325/65r18' tires on my truck. So I will defeinitely be going with an AAL for the rear of my truck.
Can't wait to see your truck when it is done. Which Fabtech kit are you going with?
The new F150s leave the factory 3" higher in back than in front. FabTech's kit is a "prerunner" kit, it's low in the back for looks and "acceleration traction" based on weight transfer to the rear.
Personally, I buy trucks for work and play - if the tail is low unladen, it is really low as soon as I add a load - not good! So, I like what some like to call the "stink bug" look. The SkyJacker kit I just got is 6" front and 4" rear, so I'll get it installed (except the Ubolts) and see if I like the look. If not, I can always add more lift to the back. I'll post pictures when it's in, but it looks like the next two weeks are going to be REALLY cold up here, so it won't be too soon!
Originally Posted by KansasJoe
I own a spring shop and I sell them, I edited my last post because the 4x4's have 5" blocks and the 2WD have 5" blocks so if you get a 4x4 kit with 2" blocks then somethings up.
Edit: That's my truck, it has fabtech 6" with half of skyjacker leveling poly spacer on it with add a leaf (my own) and arched to sit the back an inch higher than the front.
