6" suspension lift for 98 f150
Completely different systems. For the Bronco you just drop the I beams with a bracket and radius arm brackets down and put some taller coils in and you're done. The 97-03 F150 has torsion bars and you have to drop the entire system down with crossmembers and new knuckles which is why this kit is so much more because of the parts required to pull it off. The 97-03 F150 is gonna be the most time consuming lift kit to put on of any Ford truck ever built. How much lift are you looking for anyways and I'm also assuming your truck is 4x4 because 4x2's have coils on them.
