gears!!!! how hard is it???
http://www.accuautoparts.com/more.js...table=techhelp
check it out they have a gear calculator that tells all look on top right of page...
which gears to get
If your looking for near stock performance, then go with the 4.56. Those will give you plenty of torque to get around easy, and still run around the highway. But if you use your truck for recreational things like off-roading, or need/want a lot more low end torque then go 4.88, but you will be racing the engine a bit at 70. It's really about whats more important to you. I think you would be happy with the 4.56, but you would have fun with 4.88 until you have to fill up.
