Camber/Caster
Originally Posted by fx4jake31
Can you adjust the camber on the LCA's without havin to get re-aligned. I set track width is too wide in the front, the tires stick out in the front and not in the back. I have a 4" rancho
BTW... It looks like your alignment cams are both in the same place, did you have an alignment done after you installed the kit?
Funny that they both ended up in the same place after the alignment. Mine are both at different angles and I marked mine after the the tech was done so I could see if they moved. For some reason the alignment tech could not get them tight enough and they kept popping out of place-it took three alignments to get it right and I ended up using heavy loctite and cranking them down tight myself. They have not moved since!
Anyway, to answer you question....Any adjustment to those cams will mess with your alignment, hence the reason you see the LCA's moving back and forth. The only way I see to decrease track width is to get rims with more backspacing in the front so they tuck in further. Although, so much for rotating the tires so that would not work either.............
The Rancho lifts have a spacer that widens the front track width.
About 1/2" increase each side. I don't think that anything can be done to fix it. That is the main reason why I went with Superlift instead of Rancho. Superlift doesn't increase front track width. That is just my preference though. I believe most lifts do increase front track width. Procomp is another that doesn't increase track width, but it is 6". I'm not sure if there are any other 4" lifts that do not increase the front track width. I know RCD makes a 4" inch lift, but I'm not sure about the track width. I didn't bother looking because it was too expensive for me.
I think your truck looks bad a**!!
