4" Rancho Lift
4" Rancho Lift
I was wondering if anyone had used the 4" Rancho with stock 20's and 33's. My dealer says that their is conflicting advice on wether it can be done with the 20" wheels. He say that depending on where you look is says that it is anywhere from fine to only with the 17-18" or not any of the factory wheels at all? HELPPP Pics would be nice as well.
Thanks for the info guys, (or ladies?).
Copenhagen848 I noticed that you are running 35"s on your truck. Do you notice any real severe power losses. I tow a car trailer probably maxing out in the 7000lb range and I was going to stick to the 33's to avoid too much power loss. I have read in other areas of this site that people thought that even with the edge they had lost tooo much poser to tow that kind of weight.
What do you think?
Ps your truck looks real sharp
What do you think?
What do you think?
What do you think?
I definitely lost power with the 35's. I have my Edge on level 2 right now...I haven't tried it on level 3 to see if that helps any. Even though I can tell a pretty big difference in power, it's not real bad...just a little slower when starting out.
I've haven't towed anything with my setup, so I can't speak for the towing performance yet.
Hope this helps a little
I noticed a severe torque decrease. I have 4.6L 5-speed manual with 3.55 and 35". With only about 2,000 pounds in my trailer I have to ride the clutch noticeably more when starting. I also have a '85 Ski Nautique, I'm guessing around 3500lbs (correct me if I'm wrong). There is no way that I will be able to pull it out of the ramp in 2 wheel drive. When I do finally get to use my boat, I'll have to put it in 4-lo to get the boat out.
Originally Posted by mario_92551
well, i have 6" lift with 35's and the power loss i had experience is really nothing, then again it may depend on your engine size, my is a 5.4. it feels the same to me than when i was stock suspension/tires.
