Control Arms?
Control Arms?
Alright suspension guru's, I ordered some fiberglass fenders for my truck about a month ago but I havent put them on yet because I think it might look funny with the narrow wheel base. What all do I need to widen the front wheel base? Where can I get a good deal on control arms and what else would I need in order to do it? The fenders that I bought have a 6" flare on them so I need something that can bring my wheels out that far.
I dont know a whole lot, but Im learning. I understand to make a prerunner I need to replace the control arms with bigger ones to widen the stance. I just dont know what else I need. I am here in Miami only for a year then Im moving back to so cal and I want my truck to be ready to go play a little at glamis. Nothing super crazy, just nice.
You can widen the wheel base with the right choice of wheels and tires. I have 13.5" wide tires on 9" wheels and they line up real nice with the 6" glass fenders. Check my gallery. Tires are 37s - I have to "fix" the body seam at the cab end of the wheel well to avoid rubbing. Tried to flatten with a mallet, but I ain't that young anymore! Used the plasma to remove the excess metal and it works out great.
Most of the wider control arms are in lift kits. And then the back tires are still narrow as opposed to wheels which leave everything looking even!
this is what you should do to companys check out the links
http://ncdcustoms.com/html/ford.html
http://jdfabrication.com/kits/2004_f150_4x2.asp
Camburg Engineering
Contact Camburg Engineering in Huntington Beach. They make a Performance kit for your truck that will widen the stance just enough to clear 6" fenders. The kit runs $2000 plus shipping. Contact Drew at Camburg (714) 848-8880.
Also, their website shows pics of the truck, www.camburg.com
Good Luckk
-J
