help with what I need
ok heres the deal. in the next couple months I want to lift my truck. I want to be able to easily clear 37-13.5-20 Nitto Mud Grapplers without triming. My truck is a 2007 F-150 Lariat 4X4. I will also be doing the install myself. Right now I am considering either the Rize 8 in. or the CST 8 in. My question is which one is easier to install? (I dont want to have to cut anything) Also am I going to need anything other than the basic kit to clear those tiree? Do I need a leveling kit and add a leaf on top of the basic kit? i was also hoping to get some help with my wheel choises. I am looking at the KMC XD Rockstars in 20X10
or the ION Type 185 in 20X9
Is there any advantage to the 10' wide wheel as aposed to the 9"?
Thanks in advance for any help i get on this.
Marc
2007 f-150 Lariat White Sand
Flowmaster SIDO exhaust
K&N 77 intake
Edge Evo that does not work yet
Marc
K&N 77 intake
I just did 37" **** Cepek FCIIs with a 6" lift on the DC-1 wheels. If you tucked the tires at all at partial turn, it would hit at the body seam in the back of the wheel well. An 8" lift will likely have the same problem, just need to tuck it more to make contact. If you are wheeling it, it would be an issue. If you are a road warrior, probably not a huge issue. In the end, 6" lift with a 3" body lift will give you the same look and assure you won't make contact.
Originally Posted by blackf150337
you said you didnt want to cut anything? i think on all the suspension lifts except the rancho you had to cut your frame to allow the front diff to drop down. someone tell me if im wrong
I believe u will rub in sharp turns with 4.56" of BS.
Look here in the classifieds, u can find some get deals on use spacers or u could always buy new one, like autospring.
About the rear, I know with Fabtech without a AAL u are about 1" lower in the rear, so if you add say a 2" spacer you will be about 3" lower in the rear without a AAL. I would get the 4" AAL (I believe Skyjacker makes one) if that was the road u wanted to take.
