coilover?
coilover?
I want some personal opinions on which companies make the best aftermarket coilovers for a 6in lift and are adj. up to 3in? Also will the fabtech steering stabilizers work with other lifts like a RCD or BDS suspension? Im running the rcd 6in and want just a little more lift and coilovers. Also who makes the better uniball upper control arms for a new f150? total chaos makes some i think but not sure on the quality.
Camburg just came out with a new kit for 97-03 that will give 10in. of wheel travel with uniball uppers and custom spindles, limit straps and shock for 2K, if you have over an 03, look at donahoe, King, or Sway-away's for coilovers, even radflo's. Cst's Coil bucket Long travel kit would be good also, uniball uppers on that, then can upgrade to C/O's later. Other than that Total chaos would be good, if your looking for 4x4, look at Dixon Bros, and H&M. Pricy, but will blow your mind, and out perform almost everything.. 10-14in. of travel with 4x4.
