? on torsion bar cams
Originally Posted by wandell
Most people can get 2 inches of lift by cranking up their torsion bars, but each truck is different. I'd recommend staying away from the aftermarket torsion bar keys personally.
Thanks for the advice I wasnt sure why they sell the cams with the kit if there not needed,or worth the risk! if i put the 2'' blocks in how far up do you think I should crank up the front.I just want the truck to stand a little proud I dont do much off roading if I do its for hunting & its not that bad where I go,also who maks a good block & u-bolts that wont compromise the pinion angle.
