taking off the coil springs
you need to buy spring compressors if you dont already have them and then jack up your truck enough so the coil is loose from its pocket. Then unbolt the shock and then you can pull out the coil. Autozone and kragen I believe will let you buy the tool then you can return it when your done and get your money back.
Originally Posted by crashryan20
if hes asking about a coil, then his truck is most likely a 4x2 unless there something i dont know about. torsion bars are on 4x4's which dont have coils
Originally Posted by NA660rapter
i have a 2wd but im not sure what to do i dont know if it will be better to get new coil springs that give it a 2inch lift in the front or jst get the coil spring spacers. wat should i do?
if i buy the spacers will there be anything else i have to buy with it except the spring compressor.
same kit
Originally Posted by mt_b8
Is your leveling kit an above strut assembly spacer, or a poly-type coil spacer?
