2" Spacer versus 2.5" and added leaf
Okay I posted a thread earlier asking about increased tire size for once I level my 04 FX4 SCREW
That thread led to someone pointing out that a 2.5 inch leveling kit my result in my front end appearing a little higher then the rear, and the difference in wheel well spacing would be noticeable enough that I would probably want to install a Pro-Comp add-a-leafs to the rear.
I do not mind adding the leaf, but really I just want to level my truck and put on some bigger tires.
Is there some advantage over having the 2.5” spacer with a add leaf versus just a 2” spacer?
Does the add-a-leaf make for a stiffer rear ride? It already seems pretty stiff.
I am looking at the ECD 2.5 leveling kit, its powder coated billet aluminum, I want strength and no squeaking.
I am assuming that metal has to be better then polywhatever.
The only mod I have done to my truck is a Gibson catback and a remote start, so let me say thanks up front, I do appreciate all info that anyone takes time to provide.
If you want to go the 2" route, I have an EZ lift aluminum 2" spacer that I received a while back but never got around to putting it on. I felt the same way about wanting aluminum over "polywhetever" haha. I am going a different route now with the truck. I was going to get a 6" basic lift and add spacer on top, but now I will either do 6" w/coilovers or 8" rize.
i bought it from here http://www.extremetrucktoys.com/ford_lift.htm for $115
Ill let it go for 80 bucks if your interested, its just been sitting here for a couple months collecting dust, might as well sell it.
No spring compressor required.
Let me know
Let me know
Thanks if I go with the 2" I will contact you, always nice to geta deal.
I came across a thread where a guy was looking for a pic of a truck with BFG 285/65/18 tires.
Of course somebody had one but they said they took off their 2' leveling kit because of ball joint angle concerns.
How much of a concern is this?
In my spare time I like to ride my Harley not work on my truck.
My original tires need to be replaced soon, and I figure a little bigger would look good especially if I leveled it, but I certainly do not want to speed up wearing out the ball joints.
Not sure what to think at this piont, truck is 04 only 28K on it.
I have read of several running the 2" with 65K+ miles with no problems to ball joints. I think the 2.5" puts a little great strain on them. If you do go for it, just email me at rowdyt@gmail.com.
