what size tires... cause im going big!
i am planing on doing a 4 inch rough country and a 3inch PA body lift. my first question is if i cranked my torsion bars and got 3'' blocks for the rear instead of 2'' would that be like 8'' lift total instead of 7? next off with 7 or 8 inches of lift what size tires, would 36's do? by the way this is going on a 02 screw.
A buddy of mine has a 6 inch Fabtech and a 3 inch body lift. He's running 38.5s and they look great. You'll have an inch or two less lift than that so I'd say 37s would look pretty good. BTW, I have the same setup with the torsion bars/rear blocks and body lift that you're doing, and I'm debating whether to go with a 4 or 6 inch suspension lift on top of that. So I'd love to see pictures when you're done to help me decide.
i agree, go with a 6" fabtech, and then crank the torsions and add a add a leaf in the rear, this will give you about the same amount of lift, and it would be easeir than the lift and a body lift, then if you want to go bigger latter you could always add a body lift on top of it all. good luck
