Gas mileage
here are the things which you could do. Remember they are not that cheap so you at the end need to decide. you want 1-6 more mpg or not. (to get 6 you will needs to add a few of the items together)
1) tonneau cover
2) air intake
3) exhaust system
4) new headers
5) tuner/chip
6) smaller or more of a performance tire. even if the wear faster
I didn't name any of these in any specific order but with some search here and online you can figure out which one is better
Oh dont lift the truck aerodynamics will come in place ehehhehe
1) tonneau cover
2) air intake
3) exhaust system
4) new headers
5) tuner/chip
Two weeks ago, a co worker had a 95 with terrible gas mileage. Did plugs, wires, fuel/air filter himself, no change. Took it to a mom and pop shop just for diagnosis so he could do the work himself. The mechanic called an hour later, "all fixed.". Turns out the coil wasn't fully grounded. The mechanic cleaned the terminal and the thing ran like a top (charged 45 bucks). He went from getting 16ish mpg to about 8 mpg. He's back up to 16 again. Just an idea.....
1) tonneau cover
2) air intake
3) exhaust system
4) new headers
5) tuner/chip
1) tonneau cover
2) air intake
3) exhaust system
4) new headers
5) tuner/chip
You will be getting into the more expensive side of things with the Headers & Tires. So, hopefully this will give you some things to think about. Good luck...
