Leveling Kit
ya you have torsion bars sooo if you want to level it out..... in case you dont know what that is: torsion bars have adjustable preload they are big bars that go from your lower control arm to the middle of your truck. in the middle of the truck where the torsion bars end there is a torsion key for each torsion bar on the key there is are bolts that faces straight down to the ground if you tighten that bolt on the key it will tighten the preload and will raise the front of your truck. tighten each bolt on each torsion key evenly so your truck sits even. i wouldnt let the truck raise more than two inches in front due to bad angles. after your done get an aalignement! and your done... if i missed anything im sure some one can tell you.
