I have a 02 supercrew. I would like to lift it nothing major, im not sure if i should get a body lift or spend the money and get a suspension lift. I have a brush guard how would the body lift affect that? Any suggestions?
i recommend getting a suspension lift..they might be more expensive but they look alot better than body lifts do and you dont have to worry about getting gap guards with a suspension lift.how high do u want to go and what size tires do u want?
It all depends on how much money you want to spend and how high you want to go. As for gas milage, as a general rule, the taller you go and larger tire you run the worse your MPG's.
