AS 2.5 spacer question help asap!
well im gettin ready to put my 2.5" AS spacers in tomarrow and i was reading the directions and i noticed it says 2005 F-253/F-350 Super Duty and 2005 Excursion 2 1/2" leveling kit! wtf!! did they send the wrong spacers or just wrong directions?? It says all i have to do is jack it up remove shock bolts and remove shocks, remove sway bar endlinks, disconnect brake line bracket, disconnect abs line, and pull the springs out. then remove isolators and instal on top of coil spring. What do i do with the big bolts on the coil spacer? is that how the f-150 spacer installs? did they mabey send correct spacers and just wrong directions?? please help me asap!!
Heres the top and bottom of the spacer:
<a href="http://allyoucanupload.webshots.com/v/2002358157184094024"><img border="0" src="http://aycu04.webshots.com/image/16003/2002358157184094024_rs.jpg" alt="Free Image Hosting at allyoucanupload.com"/></a>
<a href="http://allyoucanupload.webshots.com/v/2002321069976389221"><img border="0" src="http://aycu06.webshots.com/image/13085/2002321069976389221_rs.jpg" alt="Free Image Hosting at allyoucanupload.com"/></a>
did you get the autospring spacer or one a billet aluminum that sits on top of the coil? I don't ahve to post handy but there is one with detailed instructions on how to install the autospring..jsut do a quick search..the other one you will have to compress the coil and would be better off taking it somewhere to get it done.
That looks like my old kit so my guess is they sold you the incorrect directions. Here's an excellent writeup, complete with pics, of how to do the install. Good luck and get some pics up as soon as it's done.
https://www.f150online.com/forums/sh...ng#post1990622
