Torsion bar problem, not your everday question
I think, no, I know something is wrong with my settings on the torsion bars. I am not familiar with these, but I know they should not be hitting the cross member. Take a look at these pics in the link and see what you think. It has a 4" lift and I can't tell if they lowered them or raised them to compensate for the rear height. I am thinking they opted to not add a leaf, put on the lift, and then lowered the bars. I may be way off, but I know it needs fixed. I just bought this truck a few weeks ago and I am trying to get it all lined out. Any advice will really help. Thanks.
https://www.f150online.com/galleries....cfm?num=13743
Looks like you've got a lot of room to go up and this is why torsion bar lift kits are considered 4-6" because you can adjust the bolt. If you want to adjust it up then you need to take all of the weight off of the front end and it will go right up with a 18mm socket. If you want to take it down then you don't need to take the weight off of the vehicle. There's nothing wrong with the way it is now so nothing needs to be "fixed" unless you want more height.
Thanks for the input. It just seems like that if they are hitting with the dropped cross member where the torsion bars connect at the rear, it would have brought them down and away from the cross member just in front of that where they are hitting. Anyway I guess I just won't worry about it for now. I may raise them an inch or so and add a leaf in the rear in the future. Thanks. And if anyone else has some ideas, let me know.
Not sure how many have owned it, but that is what I thought. It looks like there is no add a leaf and I am assuming that the block under the leafs is factory. Wandell, I was hoping to here from you. I know from reading you have experience with this. Thanks. So it would be ok th crank them up some? And add a leaf or block to bring the rear up to match?
