325/60/18 Nitto's(Rubbing)????
Hey fellas. I have a 04' supercrew 4x4. I just changed to 325/60/18 Nitto AT's on my factory wheels. There is rubbing at full turn. If installing a leveling kit will cure this, I am all about it. Will a 2 inch AS do the trick?? I've read a lot of posts and the 2inch seams to keep it level without the front jacked up. Would appreciate any advice. Thanks
I assume the rubbing is on the control arms at full steering lock. This is because of the combination of a really wide tire on a wheel with a good bit of backspacing. A leveling kit won't cure this rubbing, but it will make the truck look better. If you have rubbing on the edge of the wheelwells up front, a leveling kit will help with this.
Thanks ya'll for your help! One more question...Is there any potential risk will minor rubbing of the lower arm?? I don't do any extreme off-roading, but I do get off-road to hunt quite often. I didn't know if I need to be more carefull when going through rough stuff and if I could eventually damage something???
