Went to custom truck shop yesterday...
I have an '04 scab 4x4 8'box, 8200gvwr heavy duty suspension. In my on going quest for answers as to how to get my truck to ride softer (without spending thousands of $ experimenting), I stopped in the local truck shop and asked the question.
After a lengthy discussion with the salesman regarding changing out to progressive springs, 3" lift, 20" rims w/bigger tires. The suspension guy came in and said the single thing I could do to make the biggest difference would be to get rid of my OEM load range "E" tires and install new 20" rims with 32" tires which would have softer side walls and would make a big difference.
I've always thought going with a taller rim with a shorter sidewall would hurt. And if I were going to change tires to get a better ride, I would be better off staying with 17" or 18" rims.
Do you think going to 20's and 32" tires would make that much difference over the stock 17" and class "E" tires with 50psi in them??
tires/wheels
Looks like he's trying to make a sale imo. You are right, a shorter sidewall usually does ride rougher due to less flex in the tire itself. I would stick with a 17/18 in wheel and a c/d load range tire (unless you need the e-load rating). How about a good set of aftermarket shocks?
Originally Posted by sysman_rick
Have you considered the air bag suspension option ?
I would LIKE to keep as much of my payload capablity as I could if possible, but would let it go if it meant a better ride.
Yea, the tire thing does make some sense to me too, although I will loose some of my payload capacity.
The other part of this whole scenario is finding a set of 7 lug wheels I like, which so far I haven't found anything I'm crazy about.
