Questions about Strait Axle Conversion
I just have a few questions about doing a strait axle conversion. First, When doing a conversion do you have to change any of the 4wd out, like the transfer case or anything? Also If so what exactly do you have to change? I would expect the drive shaft and of course I know all the IFS has to come out. My buddy who owns a customs shop wants to do it to use in some shows and im just trying to understand exactly what all has to happen. Any info would be great,
~Heath
~Heath
You can keep the stock to case but u need to either get a high angle driveshaft or a indexing ring. You need to make up your mind if you want to go with coils, leafs, or coilovers. Since you are just going to use it for shows than i would keep the tcase but if it were me I get an atlas Tcase and be done with it. Mount it in place of the stock one and call up high angle driveline and get them to make you a awesome driveshaft with 1 ton ujoints. I am wanting to do a SAS on my 05 but I want to wait until my warranty is up. Ford should have made them come factory with a solid axle front end to begin with, or at least offer it as a option. Im going to go with dana 60s front and rear with an atlasII tcase.
