long travel 4x4
long travel 4x4
Does anyone know if the long travel 4x4 lift offered by Tuff country will work with a rancho or RCD 4inch lift?the reason I ask is because all you do is replace the upper and lower control arms and install the extended CV shafts. Just a thought? Then you would have about a 9in long travel suspension. Cause when you install a drop bracket lift it drops everything down including the rack and pinion so the exstentions provided should work also. I just cant seem to get in contact with these people by email. Work nights so im up when there closed. Just a thought.
