Changing Shocks on a 2004
NOPE, just remove the upper ball joint. leave the lower one on just let your hub and spinle hang on the lower arm. smack the top of the spindle with a hammer and it will drop right out. pull the whole coilover out and put it in a spring compressor (if your replacing the spacer inside the coil, if not just bolt the new spacer on top), I used one that you have to turn by hand but an air one is way easier.
