36x15.50
Originally Posted by f150mudder01
ok well if i get a 6" Fabtech lift will i be able to get on 36x15.50s with or without a wheel spacer and cranking the torsion bars.? and i will also need bushwackers lol
the CST runs kind small its more like a 7".... i only rub when its turned all the way and hit a "very small" bumb. im sure its a little diferent with a 01 f150 you maybe able to fit them.... im pretty sure theres a guy on here running a 6" fabtech and 3" body and 38x15.5 soooo maybe he will chime in.... but im sure his torsion bars are cranked way up. if i were you i would do a body lift its worth is for the look of these tires!!! haha i love them!
Yeah, I've seen several people fit 38x15.50's (on 10 inch wide wheels with 4.5 inches of backspacing) on 97-03 4x4's by using a 6 inch Fabtech and a 3 inch body lift, but that is an extremely tight fit. You may be able to fit 36x15.50's with just the 6 inch Fabtech, but you will have to crank the torsion bars up all the way and do some trimming. Personally, I'd add a body lift and be sure.
