Fabtech 6" lift or Pro Comp 6"
Originally Posted by wakebrder32
Yep sure did. I am ordering the Fabtech 6" coilover lift tomorrow with a 2.5" daystar leveling kit. thanks guys still looking for some info on the traction bars and steering stabalizer.
The coilovers are a rougher ride than stock though, they're a little stiffer.
If you are going to use a leveling kit up front, what are you using to bring the back up? (I would go with some new leaf springs..)
The kit alone will leave the rear about an inch lower. So with a 2½" leveling kit on the front, you're gonna be draggin' a$$ by 3½ inches.
I know for a fact that the mud grapplers ride fine they are just loud which I don't mind. I am certain I want the Mud Grapplers. but thanks
I've got about 8,000 miles on my 37x13.50R20s with barely any wear.
The rear springs which are on my truck are BDS with a little modification because I have 1/2 the leveling spacer up front as well. If you want to do the same with the leveling kit you would need to reuse your factory 2" block along with the leaf springs but if there is no leveling kit then you'd be all springs. Here's the link http://www.generalspringkc.com/lift_...150_04-06.html
The BDS springs are actually listed under the Fabtech section as an option
Edit: Here's a link to my BDS post with pics a while back https://www.f150online.com/forums/sh...r+leaf+springs
