Finally Lift, wheels and tires
Well I finally got what I wanted. I would like to thank everyone on the boards, especially Wandell, I did a lot of research on here and got the look that I wanted, with the correct backspacing/offset as well as the tire size I wanted. Pictures are in my gallery.
I installed the 2.5" AS kit and the rear 3" AS block. Took about 2 hours to install both last night.
The wheels are Gear Alloy 711MB 20x9 +30mm offset. The tires are BFG AT KO size 3055520.
Impact9, silver is the best isn't it? and I think the black wheels look pretty good on a silver truck.
knighj1, I got the truck on as level ground that I could I find. From the ground to the fenderwell here are the dimensions: RF 41 1/8", LF 41 1/8", RR 41 5/8", LR 41 1/2".
All in all, I am pretty happy with the stance. I just hope the front doesn't settle in too much, although the rake doesn't bother me too much. I just wanted the truck to sit higher because it is so long that it looked too low to the ground for me.
