What size lift for 33"-35" tires?
Hey all,
I have a 2000 SuperCab that is pretty much stock except for a recent MagnaFlow single out system(not shown) . I would like to move up to 33-35'" tires and new wheels but would like to get opinions on what size lift (no body lifts), or even a leveling kit, I would need to do it. I will probably stay with 16" wheels and go with 8" or 10" width. Also any opinions on offset/backspacing?
Right now I have 265/70/16 tires on the stock alloy chrome wheels.
I have been reading the site since December and have already fixed my Od. display and found out how to fix my power lock issue.
What a great bunch of folks and a great place for info, DIY fixes and mods.
Thanks in advance!
Thanks in advance!
i would go with 35's if i were you because u will always want to go bigger once u have a lift and i think 35's look better personally.rcd makes a 5" lift that will clear 35's;fabtech makes a 6" that will clear 35's;pro comp makes a 4" that will clear 35's.their all around the same price which is about $1,500.if it was me i would go with the fabtech 6,my friend just got the same lift put on his 98' and has had no problems.fabtech is a little higher quality in my opinion.
I always tell people when trying to decide between sizes (wheels, lift, etc) always go with the larger one or you will just regret it later. I'd suggest a 6 inch Fabtech or 5 inch RCD lift with some 35x12.50's on a 10 inch wide wheel with 4.5 inches of backspacing. Whether you go with 16, 17, 18 or 20 inch wheels is strictly a matter of personal preference.
Originally Posted by BSL
your torsion bars are a free leveling kit if you have a 4X4, and you should be able to get the 33's without a lift
I am looking at the Rancho 4" kit also.
Wandell, do you have more pics of your SuperCrew?
You might look at the 4.5" Superlift F.I.T. system. I have a 6" Fabtech, not installed, and might return it for the Superlift. For my needs I do not want to run 35" tires up and down the road, but would like the option to have 35" tires later on. I have read about a couple people with the Superlift on here, they seem really pleased with the lift, but there does not seem to be a lot of people running this lift yet.
