02 F150 4x4 Leveling questions
Hey Guys Im new here names Troy
Just had a few questions about leveling and maybe lifting. I read a little about torsion bars and just adjusting them. How much can I lift the front by doing so? Also, what are the biggest tires I would be able to fit if neone has a clue. I wouldnt mind adding some sort of 1 inch lift in the back to match if I could lift it that high. Basically how much can I get without actually lifting it to much as I just want a little more height for a little bigger tire. Im driving a 7700 series F150 2002 supercrew. Any advice would be greatly appreciated.
Originally Posted by TroyC
One more question...do I have to do anything to the back to fit 33's? or will they fit nicely? Also will rubbing be an issue cause if so I will just drop down one tire size....works for me thanks again.
You can fit 35x12.50's if you mount them on the OEM wheels. This is an extremely tight fit and you will have some rubbing on the frame at full steering lock. Personally, I wouldn't go that big unless you plan on lifting the truck in the near future. 35's will not fit a stock 4x4 if you mount them on wider aftermarket wheels. You will have to have at least a 3 inch body lift to fit 35's using aftermarket wheels. Remember, wheel width and backspacing are as important to fitment as tire size.
well, the dream was nice even tho it was only a dream. Im not in to lifting it that much right now. I wanna be able to park it under ground and hit a mud puddle once and a while. Id prefer to watch all you guys break your truck first Ive read some of the other threads that just seemed to pop up (after I searched them) and got a lot of info. You guys definetly know your stuff. Anyhoo, that being said one more question. what the hell is the size of a 33" tire for a 16 inch rim...315? or is that a 35"? I kept seeing those numbers and it was making me go crazy. Any suggestions on a good tire???
thanks
thanks
