Removing a Coil from a coilover shock.
Can anyone tell me how to take the coil off my coilover shock. Also I am not talking about stock stocks I have done that many times, I am talking about a sway a way shock. I have been reading up on this but no one talks about using a spring compressor so how is this done? Do you start by letting the N2 go then take the top cap off or do you start by taking the rod end off the bottom of the shock shaft after taking the preload off the spring?
