Body Lift
oh thats gonna be a problem. maybe someone who has delt with the same thing will chime in, but I'm guessin your gonna have to grind the Rhino Lining at least of the heads to expose the "hole" for the torx bit and around the boltheads as the lining will act as an adhesive holding the bolts to the bed. I think you're gonna wind up just grinding the heads off all the bed bolts...
no I didn't remove the radiator, I was able to trim the plastic tabs off with the shroud in the truck. I don't understand why the instructions tell you to remove the radiator, it would waste a lot of time...
and I didn't remove the tranny cooler either, yes u do have to bend the lines a bit and they are a bit tough to bend...
