T-bar Crank?
T-bar Crank?
Would any of you recommend a T-bar crank to level out the truck?
If so, would it be safe? Would it handle to off road driving? Will it damage anything?
Also how would I go about doing a t-bar crank? I know I need to buy a tool crank them up. Also how much do you think I should crank them? Would I need new shocks since the front will be higher? Thanks.
man i got my torsion bars tightened and i love it. i have a '97 so my truck was already level so i jus did it to get a little more hieght. It does ride diff. but it isnt as bad as i thought. i dont really notice it off road, but ony over speed bumps. It jus makes it a little bumpy. I didnt want to risk me screwing up so i jus took it to a local truck accersories place and they tightened up for 10 bux. I was in and out in buot 20 min.
Originally Posted by wandell
No, you don't need new shocks. 265's will look fine.
I plan on cranking them up about 2" depending on how "tight" they feel and look. 2" is enough were it wont cause any issues right? Because I read about that CV angle ware thing. Not quite sure. But if theres no issues then I'll crank them up 2" on stock tires and shocks.
