bed wobble
bed wobble
does anyone get the annoying bed wobble on these newer body f150's. or could it be because of my suspension and body lift? i get it mostly on the highway at about 65-70 mph. it shakes the truck as well, could this mean something else, say tires needing a re-balance? thanks guys.
I used to have it real bad between the same miles you have. I would look in my rear view and see my bed shaking like crazy. I could even feel it in my seat. I took it to get road force balanced and now it only does it maybe from 60-65 but nothing like it used to. Its a light bed shake now but atleast the seat isnt shaking anymore. Used to drive me crazy.
take it back to your dealer. the drive shaft needs to be balanced. they will add a damper kit as a "stage I" fix. if it keeps doing it then they will go to "stage II" etc... i had the damper kit installed, and it toned the vibration down a bit. i need to take it back though. i am still not happy with it. smooth road and yes it shakes yet @ aroung 60-70 not as bad, but still pretty rough.
Originally Posted by nooq
i highly doubt the will warranty the bed wobble when the truck has been lifted, especially body lift.
TSB:
Make : FORD Model : F-150 Year : 2006
Manufacturer : FORD MOTOR COMPANY
Service Bulletin Num : 04258 Date of Bulletin: JAN 01, 2006
NHTSA Item Number: 10014256
Component: POWER TRAINRIVELINE
Summary:
1ST ORDER VIBRATION FROM THE DRIVELINE AT HIGHWAY SPEEDS. *TT
Valid on '07 too?
doesn't hurt to ask...it's a known issue. they may help you out. every service dept is different
TSB:
Summary:
TSB:
Summary:
