It's here
Originally Posted by mSaLL150
i actually laughed when i saw that. great first response, way to kill the confidence.
Originally Posted by JT's F-150
Yeah, that is the way this site works. First off show how good something looks, then tell you that it is not to bad to install. After ordering squash what little confidence that i did have
Just follow the directions and take your time!!
Here is something i found for you to read besides your instructions.....
http://www.fordf150.net/howto/liftkit.php
Originally Posted by Kevin24
You have to admit it was funny
http://www.performanceaccessories.co...ns/862_863.pdf
Tells you and shows you everything you need to know, and even has pictures.
Originally Posted by Delirium
What kind of penetrating oil? I was about to start putting my PA 3" lift on tomorrow also. Don't you need a second person to hold a wrench on some of the nuts underneath while you loosen them up top or something?
front bumper help
has anyone used this kit on a '97? The kit only comes with two front mounting brackets that I am assuming are for a different year truck with a bumper that mounts with only 4 bolts, 2 on each side. At least thats what the instructions seem to indicate. My bumper however, mounts with 8 bolts, 4 on each side and therefore I am assuming I have to order two more brackets and drill some holes in the frame / bumper support?
thanks
thanks
Well another evening of fighting with this lift. I still have not got the steering extension on, i called the tech line and he said that it could be a ford problem? He said he would send me another one out. Has anyone else had this trouble?
[IMG][/IMG]
[IMG][/IMG]
I drilled holes in the crush block to mount them instead of welding them.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
