body lift???
body lift???
I put the 6" fabtech lift on my truck a little over a month ago. In my opinion the 35" tires look just a bit tight in the wheel wells.
Is a body lift extremely labor intensive? What sizes are available for my '97 4WD? Would you advise 3" or maybe a bit higher (if there is a 4" or 5" available) I dont want to get larger tires and I am guessing that a 3" lift should cost me around $250 for the parts.
If you carnk the torsion bars keep in mind the most you can get out it is 1.5". You can go to 2" you need to get an adjustable camber kit (don't recommend it).You need to look at how high you want to be at..........If the 1.5" doesn't do it for you then a body lift kit should be considered..........you need to get an alignment if you crank your torsion.
I was just reviewing the PA 3" body lift install instructions...I would be doing the install myself. I consider myself easily qualified to do the work myself- but as I am going through the steps....man I am already sweating. Im not sure I want to mess with my truck this much!
If I was doing it to someone elses ride, it wouldnt be so nerve racking
