Why coil overs?
Old 09-06-2007 | 10:52 AM
Devin4X4's Avatar
Why coil overs?
Hey guys... well im going to order the fabtech 6inch kit. Its just a matter of deciding if i should get coilovers or not? What is the real advantage with them? If i dont do much off roading are they worth the extra $$. I know they can be cranked to fit bigger tires but im going to stay with 35s.
Old 09-06-2007 | 11:02 AM
ThumperMX113's Avatar
I know you've got the money for them since you were going to do the Rize 8", get the Dirt Logics!
Old 09-06-2007 | 11:05 AM
Devin4X4's Avatar
Thump... but why? whats the advantage
Old 09-06-2007 | 11:10 AM
They're going to ride a lot better than those white body crap shocks. They're fully rebuildable. They're adjustable. They look sweet.
Old 09-06-2007 | 10:42 PM
wandell's Avatar
Yep.
Old 09-06-2007 | 10:47 PM
djh1121's Avatar
Get them, one day you be wishing you did if you don't... Just like I did.
Old 09-07-2007 | 07:19 AM
cletusjermal's Avatar
I am getting the fabtech 6" lift too. I was looking at their website and didnt see anything about coil overs for my truck. Do they not make them for my truck. I have a 2000 4x4. Also i dont really know anything about coilovers. Could u explain the difference between coil over and no coil over to me. Thanks.
Old 09-07-2007 | 11:03 AM
EBROTEN's Avatar
If your not going to use this truck off road then dont spend the extra money on Dirt Logics. It would be a waste of money.
Old 09-07-2007 | 11:33 AM
extremeethan's Avatar
two words bling bling. what looks better when you turn your wheel some crappy white shock or some bilstein shock with a spacer and still a small body shock, or a big fat badass looking shock?
Old 09-07-2007 | 11:45 AM
nooq's Avatar
Old 09-07-2007 | 01:41 PM
DL coilovers
Old 09-07-2007 | 03:20 PM
acm8705's Avatar
Your truck use torsion bars instead of springs. 1997-2003 trucks use torsion bars. The newer 2004-present use springs.
Old 09-07-2007 | 04:43 PM
wxscpo's Avatar
Agreed. If the look of the shock inside your wheel well is important to you then spend the extra money. I have the basic kit, don't regret it one bit and the ride is not bad at all.
Old 09-07-2007 | 06:51 PM
clar's Avatar
A coil over will ride harder you will loose the factory ride but is better quality than a spacer .
Old 09-07-2007 | 10:46 PM
Have you ridden in a truck with Dirt Logics or Kings?
Quick Reply: Why coil overs?
