Help with Rize 8"
Help with Rize 8"
I have decided to get the 8" from Rize. I need to know if this kit levels out your truck with the lift or if you would still need a leveling kit. I have a 2.5'' spacer right now and I dont want my truck to set too high in the front. Should I leave my spacer on and lift or take it off and lift? Could I clear 38's with it leveled? I just want my truck to set nice and level like all you other fellas out there with the rize. I know I could get an AAL to make up for the spacer but I dont want bad CV angles.
Well you need to figure out if you want to use the spacer/leveling kit or not. It'd be a good set-up for 38s but make sure you order a 4" add-a-leaf or a Deaver 4" leaf pack. The angles up front are going to be exactly like a stock truck and spacer/leveling kit. If you don't use the spacer/leveling kit than use the 6" Rize block with a 2" add-a-leaf.
I hope this helps!
I hope this helps!
