What to do to get truck a little higher?
hey. is there anything to get a little more ground clearance on my 2000 f150 4x4 without having to buy a lift, and not cranking torsion bars. is there anything possibly to do this?
there is a guy in here a couple posts down in the trail master thread that has a black supercrew with like skyjacker leaf springs and something else. any help is appreciated. sorry for the noob questions
thanks
thanks
yea i dont want a body lift
thanks anyways
https://www.f150online.com/forums/sh...d.php?t=276325
look at sean somers black f150, i like that because u can notice a difference from stock ride height. the things he has done, will that run me much money wise?
thanks anyways
the only way to gain true ground clearance is to get larger tires.... this will change the center point to a higer spot..... remember, no matter what lift you get, whether it be suspension or body..... the only way to get the differentials/axles off the ground is your tire size !!! but, you are limited if you dont want to lift.
The only thing you can do is get bigger tires which isn't going to be very big without at least cranking the torsion bars.
thanks
thanks
+another 1 on tires!!
How to get truck higher:
buy it a bag of weed and some rollin papers!
then tell your truck it can jump those railroad tracks.
Sorry, I could'nt resist. But you may want to try some taller tires. That's gonna get everything up off the ground for more clearance.
